Documentation for Users  2.0.4
Perception Toolbox for Virtual Reality (PTVR) Manual
Placing objects with 2 coordinates on Screens
😎 Reminder: If you need an extensive summary of relevant information on placing objects on 2D screens, do not forget this helpful cheatsheet.
This section is divided into the following sections:
😎 Tip: when you choose the 2D position of a symmetrical object, this position is applied to the center of this object. If the object is asymmetrical, like a chair, then this position is applied to the pivot of this object
